It is currently Sat Aug 02, 2025 7:30 am
Post new topic Reply to topic  [ 29 posts ]  Go to page Previous  1, 2
PostPosted: Sun Mar 24, 2019 11:07 am
Last Name: O'Melia
City: Huntsville
State: Alabama
I spray mine with SSII, wrap in brown paper, spray again, then wrap in foil. Let set over night. My only issue with it is that it will lift wood oils, messy. I had one fracture like that (coco), turned out it was due to a pin knot
PostPosted: Sun Mar 24, 2019 7:47 pm
First name: Jay
Last Name: De Rocher
City: Bothell
State: Washington
After pressing Indian rosewood sides sprayed with SS II overnight between paper towels, here's what the paper towels look like. Looks the same for sprayed ziricote. Does a good job of soaking up the oils mobilized by the SS II.
PostPosted: Mon Mar 25, 2019 6:06 am
First name: Willard
Last Name: Guthrie
City: Cumberland
State: Maryland 21502
Zip/Postal Code: 21502
Country: United State
Although we don't find SS2 useful or necessary with cocobolo and other rosewoods, the kraft paper used in the bending stack shows the same sort of resin transfer after bending, which saves a lot of time on what would be a bit if a job cleaning the slats and resin deposits on the surface of the wood.
- Beth Brower
PostPosted: Tue Mar 26, 2019 9:19 am
Alan Carruth wrote:
If the problem is brash fracture SS won't help: the wood is already broken. See if you can get a narrow test piece off one edge of the side you want to bend and try that. If it won't bend you'll need to laminate it.
You were not kidding! I tried it anyway. I soaked it with SS2 over night and took it to the hot pipe. Nothing would save this stuff except for lamination.
I'll tell ya too this shot my nerves. It gave me side bending PTSD or something. I soaked another side set in SS@ and bent it but my nerves were shot expecting it to break in my hands again. It didn't... Whew!
But also honestly I don't think I noticed any reall difference in bending the sides after soaking in SS2 over night. I did what some here suggested. I sprayed the boards good and wrapped them in paper and then sandwiched them between flat plywood and weighted them down with bricks. Next day I stikered them for about an hour to 'dry out' and bent them like I normally would just spritzing with water. I guess I had higher expectations or something. I was thinking the boards would feel like taffy or something. I didn't really notice a difference but I guess it's peace of mind.
These users thanked the author jfmckenna for the post: Bryan Bear (Tue Mar 26, 2019 9:21 am)
